Are these arrows supposed to forward to next record and back to previous? If so, not working, as they just scroll the table up and down.
Martyn
Martyn
You’re right - for the table view the correct, consistent behaviour should be to scroll records and not only the table view. (For the form view it works as expected.) Thanks again for reporting this.
The file was already updated (9.2.5) and published.
