- Added new “IFs” functions:
- percentileIfs(), percentileAIfs()
- averageIfs(), averageAIfs()
- geoMeanIfs(), geoMeanAIfs()
- harMeanIfs(), harMeanAIfs()
- medianIfs(), medianAIfs()
- maxIfs(), maxAIfs()
- minIfs(), minAIfs()
- varIfs(), varAIfs()
- varpIfs(), varpAIfs()
- stddevIfs(), stddevAIfs()
- stddevpIfs(), stddevpAIfs()
- modeIfs(), modeAIfs()
The above functions offer much better performance than their non-IFs variants combined with nested array plain IF’s functions. The details concerning their usage, returned error codes and examples are available in the “Formula” dialog box.
- Users can create a simple zip archive of text files (tables) which will be opened as GS-Calc workbooks with usual worksheet folders. The import options are specified as *.xml zip streams so no interaction is required during importing/opening.
- The “Settings > Options > General > Hide cell markers” option now also applies to printing (and specifies whether formula markers should be visible on the printout).
- The (missing) “<>” operator has been added to all IFs functions.
- Minor bug fixes.
