Changes and bug fixes:
All the “copy” operations are much faster now (nn-times or more for very large ranges). Previously GS-Calc copied the data both to the internal buffer for its own use and - as text - to the Clipboard, for other applications at the same time. Currently that 2nd copying stage is delayed until some application actually requests such text data accessing the Clipboard.
Text copied to the Clipboard by some of the “Edit > Copy Options” commands was truncated. (This didn’t affect GS-Calc directly as it uses an internal buffer for copying and pasting.)
The “2-mins” and “3-mins” values on the “AutoSave” and “AutoClose” lists in the “Options” dialog box were switched. Additionally, those combo boxes are now replaced by edit fields.
