Changes:
[+] Additional data validation for numeric fields. Incorrect data entered in a numeric field is rejected,
not accepted as null/0.
[+] The auto-conversion field property is not available for numeric fields.
[+] If (after copying some fields in a table view and) before executing the “Paste” command a user leaves some selected
range as a target range and if the target column is sorted then GS-Base may hang after executing the “Paste” command.
