Main new features and changes:
[+] New printing options: improved label printing, new print setup.
[+] GS-Base can now use an optional *.gsb file extension for its database *.zip files.
[+] Improved object/image (inserting and) handling.
[+] More format types displayed as graphics in binary fields.
[+] Entering both formatted and unformatted numbers and dates
as filters in the “Search” dialog box.
[+] Using the “Equal” searching mode as the default mode for numeric fields.
[+] A new “Edit > Convert Field > Replace Substrings” command performing table-based, batch character/substring substitutions for all records at once.
[+] Significantly smaller setup file size after removing the older, previously bundled graphics/jpeg library.
[+] Various bug fixes.
