Main new features and changes:
[+] A new file format: GS-Base 8.0 uses *.zip files containing tables of records as plain comma-delimited *.txt files, memo fields as either *.txt or *.rtf documents and inserted images and files in their own native formats. The self-describing structure of zip-subfolders enables you to easily and safely view and modify those zip archives even without GS-Base (which includes modifying records, adding/deleting tables, memos, images and files that can be inserted by a simple drag-and-drop operations). Those zip files can also store any number of files not used to GS-Base.
[+] 12 million rows.
[+] Pivot tables. (Up to 12 million rows x 2047 columns.)
[+] Form views, better configurable splitters.
[+] New formulas in calculated fields: cross-table summarizing and counting.
[+] Definable and searchable record flags.
[+] Stronger (standard) encryption protecting contents of every field type.
[+] Significantly increased speed of many functions.
[+] A lot of improvements concerning editing functions.
[+] Better file shortcut support for both plain text and binary (“Images/Files”) fields.
