The beta version will be available to registered users for a short time.
Sample screen: http://www.citadel5.com/gsb80_scr1.png.
Some of the new features and changes:
[+] A new file format: GS-Base 8.0 uses *.zip files containing tables of records as plain comma-delimited *.txt files, memo fields as either *.txt or *.rtf documents and inserted images and files in their own formats. The self-describing structure of zip-subfolders enables you to easily and safely view and modify those zip archives even without GS-Base. This includes modifying records, adding/deleting tables, memos, images and files that can be inserted by a simple drag-and-drop operations. Those zip files can also store any number of files not related to GS-Base.
[+] 12 million rows.
[+] Pivot tables. (Similarly to the main record tables: up to 12 million rows x 2047 columns.)
[+] Form views, better configurable splitters.
[+] Definable and searchable record flags.
[+] Stronger (standard) encryption protecting contents of every field type.
[+] Significantly increased speed of many functions.
[+] A lot of improvements concerning editing functions.
[+] Better file shortcut support for both plain text
and binary (“Images/Files”) fields.
