New features in GS-Base 19.4:
- SQLite *.db format support. You can load/save *.db databases with tables containing up to 256 million records, including tables with formatted LongText and BLOB objects (files, images). Similarly to other supported formats (text/csv/xls/xlsx/dbase/xbase/mysql) by default all those files can be opened/used/edited in-place, without changing the file format or their parameters.
The SQLite *.db format thanks to its popularity can be a good alternative to the CSV/text files when it’s important to avoid any possible inconsistencies and differences in how various programs might convert CSV/text data.
