- Creating and saving pivot table reports as new tables with automatically time-stamped names.
https://citadel5.com/upd_screens/gsb16.3/gsb16.3_scr1.png
https://citadel5.com/upd_screens/gsb16.3/gsb16.3_scr2.png
- The “Copy Pivot Table” command has been added and the “Save As” command has been moved to the “Copy” menu as “Copy To File…”.
- The string/error code displayed in pivot tables to denote #N/A! - “not available data”
can be customized using a new option in the Pivot Table setup window.
https://citadel5.com/upd_screens/gsb16.3/gsb16.3_scr3.png
- The “Select All” command in the “Copy With Options” dialog box switches sequentially
between three copied field selection ranges (original selection, all “on”, all “off”).
ver. 16.3.1 - 06/28/2019
- A bug fix: calculated fields with formulas containing references to fields that use validation formulas are not recalculated.
ver. 16.3.2 - 08/24/2019
- The “And:” field search filter has been changed not to require the “*” special character in strings. It causes searching for substrings by default now.
