GS-Base 16.1 has been released
  • Dual database views enabling you to edit/view two tables independently.
    Sample screenshots:
    https://citadel5.com/upd_screens/gsb16.1/gsb16.1_scr1.png
  • Displaying the one-to-many relation between two tables in dual views.
  • Splitting views using a mouse (instead of the “Split” commands used previously).
  • Text wrapping in forms can be optionally turned off.
  • Search keys can be easily updated/edited and sorted.
  • The “Sort” button automatically switches between the three states: “ascending”, “descending” and “no sorting”.
  • Corrections in the cross-table formula descriptions.
  • The database explorer pane width doesn’t change when resizing the main window.
ver. 16.1.2 - 11/9/2018
  • A fixed problem with using TAB when editing plain text fields.
  • Added missing prompt/help status line messages explaining how the Edit > [Operations | Increment | Decrement] commands can be used.
ver. 16.1.5 - 30/03/2019
  • A maintenance update and a bug fix.
