ver. 15.9 - 12/9/2017:
- The “Statistics” edit field in the “Field Setup” dialog box now shows also the binary fields (size) statistics and the date statistics (for text fields with the date/time styles set).
- Three new commands have been added to the context menu in binary fields:
- “Load Files From Folder” - importing all files from a given folder to the current field,
- “Save All Files To Folder” - exporting all files from the current field to a given folder,
- “Open In External Application” - as opposed to the similar “Edit in (…)”, the external application for this command can be redefined easily manually in Windows using the “Opens with” Windows file property.
- The text strings related to binary fields and displayed in tables are now accessible in formulas.
