ver. 15.8 - 12/30/2016:
- Users can easily create a simple zip archive of text files (tables) which will be opened as native GS-Base databases (with the same speed and without any interaction). For details, please see
http://www.citadel5.com/help/gsbase/simple_file_format.htm
http://www.citadel5.com/help/gsbase/file_format.htm . - Additional text import/export options.
- The “Treat empty field values as zeroes” (pivot table) option now just controls whether empty input fields are treated as zero values or ignored in calculations.
- Bug fixes.
ver. 15.8.3 - 2/18/2017:
- If an array formula is used in a text field, its value is now accepted as the corresponding string, that is {x1, x2, x3; x4…}
- Bug fixes.
ver. 15.8.4-5 - 5/4/2017:
- Recreating nested folders in custom (manually) created zip files.
ver. 15.8.7-8 - 7/29/2017:
- Minor updates.
