I am using GS-Calc v. 15, 64 bit in Windows 7 Ultimate. I copied a calculated column of numbers and pasted w/o formula to a new worksheet so they would be standalone. Using find and replace to change some values, I found replacing 2 with 0 resulted in every number that contained a 2 turned into a 0, e.g. 23 became 3. I have the options set to exact matching (Plain text full content matching). Using find only it will skip over the 23 and only find the 2s.
I tried this in a new workbook manually typing in numbers and it did the same thing. I also tried replacing the 3s and 4s and the same thing happened.
I tried this on my laptop with v. 16 trial and the bug was not present, so I’m going to have to upgrade.
Another suggestion: Make newer versions backwards-compatible. I can’t open the v. 16 file I created on my laptop.
